Need help in how to set up a proposed network solution
imnotapro
I don't know if this is even possible or if its beyond the scope of what Asus routers / Merlin firmware is capable of but here we go.
I currently have an ESXi server that is running virtualised pfSense as my router and firewall. I am currently using my ASUS RT-AC3200 as an access point to provide internet to all the wireless devices in my network.
What I want to do is create 5 wireless networks each with its own subnet and IP's that a device can connect to based on what it is. Each SSID should be assigned to each port on the ASUS router as follows.
Here is what I had in mind:
pfSense LAN -> WAN port -> SSID: WiFi_Admin - IP: 192.168.1.0
pfSense port 1 -> eth0 (LAN port 1 on ASUS router) -> SSID: WiFi_Home - IP: 192.168.2.0
pfSense port 2 -> eth1 (LAN port 2 on ASUS router) -> SSID: WiFi_VPN - IP: 192.168.3.0
pfSense port 3 -> eth2 (LAN port 3 on ASUS router) -> SSID: WiFi_IoT - IP: 192.168.4.0
pfSense port 4 -> eth3 (LAN port 4 on ASUS router) -> SSID: WiFi_Guest - IP: 192.168.5.0
So to explain, there will be 5 SSID networks. Each SSID will correspond to a port on the router which will be connected to pfSense and depending on what SSID a device connects to they will be on that subnet. I want pfSense to also hand out DHCP leases so I need the ASUS router to query the pfSense DHCP server.
What I'm trying to achieve is network segmentation based on what device connects to it and prevent one device on one SSID see another on a different SSID which I understand I will have to play with pfSense's firewall rules to acheive this.
I think a better of describing what I want to do is:
Create 5 bridges. Each bridge will be assigned a port on the router. That bridge will also have 2 SSID's (2.4 & 5 Ghz) and each bridge will be given its own subnet and then all traffic will be routed to pfSense which will provide it with DHCP leases and internet access
Tl;Dr: I want to create 5 SSID's with each SSID corressponding to a port on my ASUS router and then connect all 5 ports to my pfSense machine so they all each have their own network.
Im no expert but do understand i think what your wanting. It would make sense to me that most of your work there would need to be done on the pfsense machine thats handing out the ip's. You could easily achive this with 5 routers obviously each with theyre own dhcp but with your setup the pfsense box will need to know what port a device is connected on and hand out ip's based on that. Ive never used pfsense so unfortunatly cant help you with how to do it if its even possible.
If you get an access point that handles VLANs this is easily done. The AC3200 won't do for this application. FYI, individual Ubiquiti Unifi access points support 4 SSIDs using VLANs. I have this working well here though only using 3 SSIDs.
I'm pretty sure that you can't do vlan tagging with most home based routers. You may have better luck looking into doing this with dd-wrt.
I can handle the pfSense side of things, It's just how would I go about getting the router to query the DHCP server on pfSense instead of using it's own DHCP server. When I put the router into AP mode, it queries pfSense for DHCP leases but then I can't do anything else, simply because I don't know how to.
I've been doing some searching and discovered bridging and what not. If I could create 5 bridges on the router, with each bridge assigned to a port on the router and then set those bridges up with it's own IP and SSID and set the bridge to query pfSense for leases I think I could achieve what I want.
