Hello, I've been having some intermittent bad luck with the pair of trendnet 'green' switches (different models) I am currently using. 1st worked fine added a second to the network and problems started.
I need recommendations for a reliable router and 2 gigabit switches as replacements.
I am attaching a rough diagram of my expected topology below. I would like a router with a dual wan capability, It should work easily with 'back to my mac', plex, ATA adapter, maybe sling-box in the future, easy setup. Switches I would like the ability to use link aggregation (port trunking?) between themselves and to my NAS. possibly to the router? Probably limited by WAN speed there? Or if there is a router with an appropriate number of ports?
IP cameras may be a future add-on, not sure for topology approach for those at this time.
