Network question
stevenc152
Hello All,
Been ages since ive worked hands on with hardware,
I have a high traffic home network
5 pcs , few consoles, laptops, tvs with network streaming, wireless devices for streaming and a few odds and ends that use the internet.
Most coming from gaming so low pick and high network traffic routing is what i want.
I bought a high end router, Have a few 4 port switches, nothing fantastic.
I was contemplating buying a cisco switch and routing everything from that out, I can setup cables fine thats not a problem.
Any recomendations or advise on this (I hate programing switches, avoid if i can, happy go to other companies if its a big port switch.
Sorry, but I don't understand your "routing" needs. What is wrong with your current setup?
Hello All,
They first order question you have is what speed your ISP actually provides in the busy hour, and what delay/latency your Internet-based gaming servers have.
Fiddling with layer 2 switches is # 99 on the issue list.
Just addressing that he doesn't need all the things he has mentioned. An RT-N66U should handle everything he has. Plus be cheaper then buying a few switches. I'm with Tim he hasn't addressed his needs in full.
