Nodes disconnect fron AX86U AI-Mesh
Harl
I have an AI-Mesh with an AX86U as router two AC67 and one AC68 as nodes, the AC68 was the previous router, and since I upgraded the mesh with the AX86 the AC67 fríos fron the mesh every couple of days they disconnect fron the mesh for about 30s all the decides connected yo them lose Internet connection (even the wired) and the main router show them as disconected.
The log fron last drop
Nov  6 11:57:12 rc_service: ntp 2060:notify_rc restart_diskmon
Nov  6 11:57:12 disk_monitor: Finish
Nov  6 11:57:12 disk monitor: be idle
Nov  6 11:57:13 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Nov  6 11:57:13 kernel: x_tables: ip_tables: mac match: used from hooks FORWARD/OUTPUT, but only valid from PREROUTING/INPUT/FORWARD
Nov  6 11:57:15 zcip client: configured 169.254.183.218
Nov  6 11:57:17 kernel: SHN Release Version: 2.0.1 4b635f32
Nov  6 11:57:17 kernel: UDB Core Version: 0.2.18
Nov  6 11:57:17 kernel: sizeof forward pkt param = 280
Nov  6 11:57:17 kernel: The For ALL DEVICES flag of Prof 2 has been set to ENABLE
Nov  6 11:57:17 BWDPI: fun bitmap = 43f
Nov  6 11:57:17 kernel: The For ALL DEVICES flag of Prof 1 has been set to ENABLE
Nov  6 11:57:18 wlceventd: wlceventd_proc_event(499): eth6: Auth 74:EE:2A:5D:90:38, status: Successful (0)
Nov  6 11:57:18 wlceventd: wlceventd_proc_event(527): eth6: Assoc 74:EE:2A:5D:90:38, status: Successful (0)
Nov  6 11:57:19 nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Nov  6 11:57:19 kernel: x_tables: ip_tables: mac match: used from hooks FORWARD/OUTPUT, but only valid from PREROUTING/INPUT/FORWARD
Nov  6 11:57:19 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Nov  6 11:57:19 kernel: HTB: quantum of class 10002 is big. Consider r2q change.
Nov  6 11:57:19 kernel: HTB: quantum of class 10060 is big. Consider r2q change.
Nov  6 11:57:19 kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Nov  6 11:57:19 kernel: HTB: quantum of class 10040 is big. Consider r2q change.
Nov  6 11:57:20 kernel: HTB: quantum of class 20010 is big. Consider r2q change.
Nov  6 11:57:20 kernel: HTB: quantum of class 20040 is big. Consider r2q change.
Nov  6 11:57:20 wlceventd: wlceventd_proc_event(481): eth6: Disassoc E0:CC:F8:77:FC:3A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Nov  6 11:57:21 kernel: ubi2: attaching mtd10
Nov  6 11:57:21 kernel: ubi2: scanning is finished
Nov  6 11:57:21 kernel: ubi2: attached mtd10 (name "misc1", size 8 MiB)
Nov  6 11:57:21 kernel: ubi2: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Nov  6 11:57:21 kernel: ubi2: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Nov  6 11:57:21 kernel: ubi2: VID header offset: 2048 (aligned 2048), data offset: 4096
Nov  6 11:57:21 kernel: ubi2: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Nov  6 11:57:21 kernel: ubi2: user volume: 1, internal volumes: 1, max. volumes count: 128
Nov  6 11:57:21 kernel: ubi2: max/mean erase counter: 6/2, WL threshold: 4096, image sequence number: 1725884149
Nov  6 11:57:21 kernel: ubi2: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
Nov  6 11:57:21 kernel: ubi2: background thread "ubi_bgt2d" started, PID 2393
Nov  6 11:57:22 kernel: ubi: mtd10 is already attached to ubi2
Nov  6 11:57:22 kernel: UBIFS (ubi2:0): background thread "ubifs_bgt2_0" started, PID 2438
Nov  6 11:57:22 kernel: UBIFS (ubi2:0): UBIFS: mounted UBI device 2, volume 0, name "nvram"
Nov  6 11:57:22 kernel: UBIFS (ubi2:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Nov  6 11:57:22 kernel: UBIFS (ubi2:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
Nov  6 11:57:22 kernel: UBIFS (ubi2:0): reserved for root: 0 bytes (0 KiB)
Nov  6 11:57:22 kernel: UBIFS (ubi2:0): media format: w4/r0 (latest is w4/r0), UUID 4B2A44DD-417E-46D8-97CE-24D278768884, small LPT model
Nov  6 11:57:23 wlceventd: wlceventd_proc_event(464): eth6: Deauth_ind 74:EE:2A:5D:90:38, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Nov  6 11:57:29 wlceventd: wlceventd_proc_event(499): eth7: Auth 74:EE:2A:5D:90:38, status: Successful (0)
Nov  6 11:57:29 wlceventd: wlceventd_proc_event(527): eth7: Assoc 74:EE:2A:5D:90:38, status: Successful (0)
Nov  6 11:57:36 crond[1440]: time disparity of 1319392 minutes detected
Nov  6 11:58:51 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6361)]periodic_check AM 4:24
Nov  6 11:58:51 hour monitor: ntp sync fail, will retry after 120 sec
Nov  6 11:58:55 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6391)]retrieve firmware information
Nov  6 11:58:55 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6408)]no need to upgrade firmware
Nov  6 12:00:12 disk_monitor: Got SIGALRM...
Nov  6 12:10:04 wlceventd: wlceventd_proc_event(499): eth6: Auth 28:16:7F:29:BA:A2, status: Successful (0)
Nov  6 12:10:04 wlceventd: wlceventd_proc_event(509): eth6: ReAssoc 28:16:7F:29:BA:A2, status: Successful (0)
Nov  6 12:10:25 wlceventd: wlceventd_proc_event(464): eth6: Deauth_ind 28:16:7F:29:BA:A2, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
