OpenVPN server routing / DNS issues
evo17paul
Hi, long time viewer new poster
Successfully updated brand new AX86U to 388 beta 1 and taken most of my settings (from screenshots) from my previous AC87U.
I'm a bit lost with OpenVPN server. I've configured as per my previous settings and previously I would run OpenVPN Client on my android phone. Now after configuring the server and having it running, I can successfully connect no problem and I can see my LAN subnet being routed (through the openvpn client log messages), a d my PiHole DNS servers. However if I try and browse I'm getting no connection.
Can anyone help or provide guidance. Only changes is my phone to OOS12 and the AX86U in my environment.
ps
I'm trying connection whilst of my WiFi and using 4G mobile network
Thanks in advance
evo17paul
ps
Thanks in advance
Ignore, found the problem and nothing to do with Merlin.... PIhole diagnosis gave me the answer, and an adjustment on my Pihole settings
L&LD
Part of the Furniture
Please share your newfound wisdom. Let others benefit too.
evo17paul
Apologies of course
Basically in PiHole settings for DNS had Only allow local requests, meaning the local subnet. That's the recommended setting.
Change to Permit all origins, once you've read the pre-requisite warnings, and you can serve DNS to other subnets.
Also worth noting within OpenVPN Server settings I'm pushing dhcp-options for my primary and secondary piholes
Hope it helps anyone else
