Own Reset Config
shure007
Hey,
is it possible to create my own reset settings when pressed the reset button on the device?
Other DHCP Range, etc...
OK. Is this possible?
Anything's possible if you have the time and skills required. As a minimum you'd need some basic understanding of how to edit and compile C programs in a Linux environment. In addition to that, compiling a complete firmware from source presents its own challenges. Have a look at this recent thread about the subject, particularly post #42. If that doesn't mean anything to you I'd suggest that it's probably above your current skill set.
