Protected Management Frames option in 386.3
Jano Drotar
after upgrade to 386.3 I realised wifi performance issues on my AX86U, that were before solved by disabling Protected Management Frames option in Wireless general settings.
But now I do not see this option any more.
Was this option removed due to some security issues or it's just some dirty upgrade problem ?
Thanks for the feedback.
Still there in Wireless General. Might have to refresh your browser.
Thanks for the feedback. I do not see it, so seems have to do clean FW update.
I see the General Page on your router looks different compared to mine and @kernol 's router... Maybe the reason is that you use Smart Connect. Why not disable the Smart Connect and see what will happen?
I don't have a router that supports it to check, but the option may be hidden if you have WPA3 authentication selected, since WPA3 requires PMF.
+1 Option will not show if WPA3 is not enabled. If not WPA3 only at least WPA2/WPA3 is.
Smart connect is on for my AX86u unit and protected frames shows. I suggest OP starting over as something is off there.
What I see when changing Authentication method. @john9527 was right....
Edit: Didn't actually change/apply settings but did change method to show above screenshot.
It's back again. I did just some configuration changes (disabling/enabling MU-MIMO, changing some parameters for Roaming assistant) and Protected Management Frames option is back again ....
Thanks again for the feedback ....
