RT-AC66R Merlin Firmware not showing Traffic Manager per device
btrotter
I bought the RT-AC66R today from Best Buy. I brought it home and flashed it with Merlin version 374.41. The documentation said I would be able to see Per Device bandwidth stats. When I go to Traffic Manager, under all the dropdown (Realtime, Daily, etc), I dont have anything which shows per device. Only the standard Internet, Wired, Wireless 2.4Ghz, Wireless 5Ghz.
Another thing I find odd is by default the Internet graph displays when showing Realtime. If I click off to select anything else (example, Wired). It shows Wired for about 1 second and jumps back to Internet. I cant get it to not jump back to Internet.
I have attached a screenshot.
Hey btrotter,
You have to "Enable IP Traffic (per IP monitoring)" under TOOLS / OTHER SETTINGS.
I would reboot your router after doing so.
Cheers!
Thank you. That gets the Per Device stats.
I noticed it does still have the bizarre behavior where it keeps going back to Internet when I click one of the tabs. Seems like either a bug or a browser problem.
This is a browser problem. I confirmed it does it on my Mac when using Chrome or Firefox but not Safari. I tested on a Windows PC using Chrome and it worked.
