I have a RT-AC66U and it constantly drops connection. I am on firmware 3.0.0.4.376_3602. What am i doing wrong? Here is a log of the startup.
Dec 31 18:00:11 syslogd started: BusyBox v1.17.4
Dec 31 18:00:11 kernel: klogd started: BusyBox v1.17.4 (2014-11-04 22:06:22 CST)
Dec 31 18:00:11 kernel: start_kernel
Dec 31 18:00:11 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.3) #1 Tue Nov 4 22:09:24 CST 2014
Dec 31 18:00:11 kernel: CPU revision is: 00019749
Dec 31 18:00:11 kernel: Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Dec 31 18:00:11 kernel: Determined physical RAM map:
Dec 31 18:00:11 kernel: memory: 07fff000 @ 00000000 (usable)
Dec 31 18:00:11 kernel: memory: 08000000 @ 87fff000 (usable)
Dec 31 18:00:11 kernel: Built 1 zonelists. Total pages: 585216
Dec 31 18:00:11 kernel: Kernel command line: root=/dev/mtdblock3 console=ttyS0,115200 init=/sbin/preinit
Dec 31 18:00:11 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Dec 31 18:00:11 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Dec 31 18:00:11 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Dec 31 18:00:11 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Dec 31 18:00:11 kernel: Using 300.000 MHz high precision timer.
Dec 31 18:00:11 syslog: module ledtrig-usbdev not found in modules.dep
Dec 31 18:00:11 syslog: module leds-usb not found in modules.dep
Dec 31 18:00:11 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 31 18:00:11 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 31 18:00:11 kernel: Mount-cache hash table entries: 512
Dec 31 18:00:11 kernel: PCI: Initializing host
Dec 31 18:00:12 kernel: PCI: Reset RC
Dec 31 18:00:12 kernel: PCI: Initializing host
Dec 31 18:00:12 kernel: PCI: Fixing up bus 0
Dec 31 18:00:12 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Dec 31 18:00:12 kernel: PCI: Fixing up bridge
Dec 31 18:00:12 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Dec 31 18:00:12 kernel: PCI: Fixing up bus 1
Dec 31 18:00:12 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Dec 31 18:00:12 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Dec 31 18:00:12 kernel: PCI: Fixing up bus 2
Dec 31 18:00:12 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Dec 31 18:00:12 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Dec 31 18:00:12 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Dec 31 18:00:12 kernel: highmem bounce pool size: 64 pages
Dec 31 18:00:12 kernel: pflash: found no supported devices
Dec 31 18:00:12 kernel: Boot partition size = 262144(0x40000)
Dec 31 18:00:12 kernel: Creating 2 MTD partitions on "sflash":
Dec 31 18:00:12 kernel: 0x00000000-0x00040000 : "pmon"
Dec 31 18:00:12 kernel: 0x001f0000-0x00200000 : "nvram"
Dec 31 18:00:12 kernel: Found a Zentel NAND flash with 2048B pages or 128KB blocks; total size 128MB
Dec 31 18:00:12 kernel: lookup_nflash_rootfs_offset: offset = 0x0
Dec 31 18:00:12 kernel: nflash: squash filesystem with lzma found at block 9
Dec 31 18:00:12 kernel: Creating 4 MTD partitions on "nflash":
Dec 31 18:00:12 kernel: 0x00000000-0x02000000 : "linux"
Dec 31 18:00:12 kernel: 0x00134ebc-0x02000000 : "rootfs"
Dec 31 18:00:12 kernel: 0x04000000-0x06000000 : "linux2"
Dec 31 18:00:12 kernel: 0x04134ebc-0x06000000 : "rootfs2"
Dec 31 18:00:12 kernel: Creating 3 MTD partitions on "brcmnand":
Dec 31 18:00:12 kernel: 0x00000000-0x02000000 : "trx"
Dec 31 18:00:12 kernel: 0x04000000-0x06000000 : "asustrx2"
Dec 31 18:00:12 kernel: 0x06000000-0x07f00000 : "brcmnand"
Dec 31 18:00:12 kernel: dev_nvram_init: _nvram_init
Dec 31 18:00:12 kernel: u32 classifier
Dec 31 18:00:12 kernel: OLD policer on
Dec 31 18:00:12 kernel: Netfilter messages via NETLINK v0.30.
Dec 31 18:00:12 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Dec 31 18:00:12 kernel: ipt_time loading
Dec 31 18:00:12 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 18:00:12 kernel: net/ipv4/netfilter/tomato_ct.c [Nov 4 2014 22:08:47]
Dec 31 18:00:12 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 18:00:12 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Dec 31 18:00:12 kernel: Warning: unable to open an initial console.
Dec 31 18:00:12 kernel: Failed to execute /sbin/preinit. Attempting defaults...
Dec 31 18:00:12 kernel: Algorithmics/MIPS FPU Emulator v1.5
Dec 31 18:00:12 kernel: et: module license 'Proprietary' taints kernel.
Dec 31 18:00:12 kernel: et_module_init: passivemode set to 0x0
Dec 31 18:00:12 kernel: et_module_init: et_txq_thresh set to 0x400
Dec 31 18:00:12 kernel: bcm_robo_enable_switch: EEE is disabled
Dec 31 18:00:12 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
Dec 31 18:00:12 kernel: wl_module_init: passivemode set to 0x0
Dec 31 18:00:12 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Dec 31 18:00:12 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Dec 31 18:00:12 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Dec 31 18:00:12 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.163.2002 (r382208)
Dec 31 18:00:12 kernel: SCSI subsystem initialized
Dec 31 18:00:12 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c01f8000
Dec 31 18:00:12 kernel: NTFS (with native replay) support included
Dec 31 18:00:12 kernel: optimized: speed
Dec 31 18:00:12 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Dec 31 18:00:15 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Dec 31 18:00:15 stop_nat_rules: apply the redirect_rules!
Dec 31 18:00:15 WAN Connection: ISP's DHCP did not function properly.
Dec 31 18:00:19 dnsmasq[340]: warning: interface ppp1* does not currently exist
Dec 31 18:00:19 RT-AC66U: start httpd
Dec 31 18:00:19 RT-AC66U: start httpd - SSL
Dec 31 18:00:19 syslog: Generating SSL certificate...
Dec 31 18:00:21 pptpd[378]: MGR: Config file not found!
Dec 31 18:00:21 disk monitor: be idle
Dec 31 18:00:21 miniupnpd[380]: HTTP listening on port 33299
Dec 31 18:00:21 miniupnpd[380]: Listening for NAT-PMP traffic on port 5351
Dec 31 18:00:25 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Dec 31 18:00:25 rc_service: udhcpc 413:notify_rc stop_pptpd
Dec 31 18:00:25 rc_service: udhcpc 413:notify_rc start_pptpd
Dec 31 18:00:25 pptpd[416]: MGR: Config file not found!
Dec 31 18:00:25 pptpd[430]: MGR: Config file not found!
Dec 31 18:00:27 rc_service: udhcpc 413:notify_rc stop_upnp
Dec 31 18:00:27 miniupnpd[380]: received signal 15, good-bye
Dec 31 18:00:27 rc_service: udhcpc 413:notify_rc start_upnp
Dec 31 18:00:27 ddns update: ez-ipupdate: starting...
Dec 31 18:00:27 miniupnpd[481]: HTTP listening on port 37008
Dec 31 18:00:27 miniupnpd[481]: Listening for NAT-PMP traffic on port 5351
Dec 31 18:00:27 ddns update: connected to ns1.asuscomm.com (103.10.4.108) on port 80.
Dec 31 18:00:28 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Tue, 09 Dec 2014 15:33:52 GMT^M Server: Apache/2.4.9 (Unix) PHP/5.5.14 OpenSSL/1.0.1h^M X-Powered-By: PHP/5.5.14^M Content-Length: 0^M Connection: close^M Content-Type: text/html^M ^M
Dec 31 18:00:28 ddns update: retval= 0, ddns_return_code (,200)
Dec 31 18:00:28 ddns update: asusddns_update: 0
Dec 31 18:00:28 ddns: ddns update ok
Dec 31 18:00:28 rc_service: udhcpc 413:notify_rc stop_ntpc
Dec 31 18:00:28 rc_service: udhcpc 413:notify_rc start_ntpc
I am constantly getting this.
rc_service: udhcpc 484:notify_rc start_ntpc
