Solved RT-AC68U; 386.3_beta3 firmware Command not working
jsarcone
I have RT-AC68U; 386.3_beta3 firmware. I'm getting NVRAM 63431 / 65536 bytes. I have attempted to
'nvram show | grep =$ '; do var=${line%*=}; nvram unset $var; done; nvram commit
but I get a "do" error. I don't know why. Would some know how to correct this? Thank you in advanced.
dave14305
Part of the Furniture
You’re missing the beginning of the statement with for line in… Go back to the source of the command.
dave14305
BTW, quite a few valid, populated, encrypted password nvram variables would get unset if I ran this on my own router. Use caution.
jsarcone
Thank you for the reply. What other ways can you reduce the NVRAM consumption or is it time for a new router. I don't use the WiFi, which, is disabled. Any suggestions or advice?
ColinTaylor
The optimal method, if you haven't done so already, is to factory reset the router and then manually configure it.
