1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
RT-AC86U 5Ghz issue
Discussion in 'ASUS AC Routers & Adapters' started by Vezeil, Jun 2, 2020.
  1. Vezeil
    Vezeil New Around Here
    Jun 2, 2020
    8
    So i got my new ac86u today, installed it changed some settings and stuff, everything worked fine for 1 hour i did a speedtest on my phone to check the 5ghz and the result was 0mbps, after 10 minutes it kicked me from the 5ghz and from then i can't connect to it, i tried a factory reset, updating the firmware but nothing works.
    I did google the problem and i found some threads from here with the same problem, is the only thing i have left to do is get a replacement or there is some solution to it.
  2. OzarkEdge
    OzarkEdge Part of the Furniture
    Feb 14, 2018
    2,753
    USA
    Make sure the WiFi switch is ON; try with another wireless client; otherwise, exchange it for a new one.
    OE
    Vezeil likes this.
  3. bbunge
    bbunge Very Senior Member
    Aug 11, 2014
    1,217
    Pennsylvania USA
  4. Vezeil
    Jun 2, 2020
    8
  5. Vezeil
    Jun 2, 2020
    8
    Well now even the 5ghz LED doesn't work. smh
    [​IMG]
    [​IMG]
    where are the channels what.
    Radio is enabled
  6. ColinTaylor
    ColinTaylor Part of the Furniture
    Mar 31, 2014
    12,114
    UK
    When it's showing channel 0 that usually means a hardware failure of the radio. The unit needs to be replaced.
    You could try completely removing the power for 60 seconds and then plugging it back in and seeing if the fault corrects itself. Otherwise you're SOL.
    bitsbytes and Vezeil like this.
  7. L&LD
    L&LD Part of the Furniture
    Dec 9, 2013
    13,026
  8. bbunge
    Aug 11, 2014
    1,217
    Pennsylvania USA
  9. Vezeil
    Jun 2, 2020
    8
    I'll give it a try but first i have some update.
    I unplugged the router from everything and let it rest for like 10 minutes, turned it on and pressed the reset button behind the router for my surprise the 5ghz LED was on
    so i thought great i fixed it but yeah...no.. First the connection to the router site was really really slow and at one point it was just stuck so i rebooted it again, everything went fine
    5ghz led is on but sure i still can't connect to it(no matter which channel), the SSID was flashing on and off on my phone.. In the end i was looking at some settings and without changing anything it lagged again...rebooted the router and the 5ghz LED turned off....
    I turned it off for another 10min and the 5g LED turned on.... idk man..weird.
    So basically when the 5g Led is on i can't connect to it anyways (even if it shows on my phone without disappearing) and when the LED is off the whole router goes boom
    Idk i think the router is just broken, I barley touched any settings in my first hour with it and it just went boom.
  10. ColinTaylor
    Mar 31, 2014
    12,114
    UK
    It happens (the same as any product). Better that it happens now so you can get it replaced rather than in 13 months time.
  11. bbunge
    Aug 11, 2014
    1,217
    Pennsylvania USA
    Sill, you should try a factory reset, basic config and reflash the Asus firmware.
  12. Sachb
    Sachb Regular Contributor
    May 11, 2016
    115
    I read somewhere that the 2018 and the earlier models have this issue. What year is your router manufactured in?
  13. OzarkEdge
    Feb 14, 2018
    2,753
    USA
    I just read that somewhere, too! :rolleyes:
    OE
    Sachb likes this.
  14. Vezeil
    Jun 2, 2020
    8
    2018
    Had it off for the entire night, turned it on in the morning managed to connect once got 0.5mbps in speedtest and then after 2minutes it logged me off, 30minutes later 0 channels again so yeah..
    talked with asus support on the phone they will look into it.
  15. CaptainSTX
    CaptainSTX Part of the Furniture
    May 2, 2012
    2,553
    A number of units manufactured in 2018 had many issues, the most frequent the radios. Short product life by some purchasers was also another complaint. If your unit is still in warranty have ASUS issue an RMA. If you are out of warranty time to buy another router.
  16. Sachb
    May 11, 2016
    115
    My RT-AC88U had the same issue, but this was my fault as I increased the transmit power on it to 1 watt, but it didn't give up like yours, It still seems to work but is in bad shape I believe. I believe mine will work for few hours or even mins and will ultimately drop Wifi.
    Now the only thing you can do is get a replacement unit, or buy something else. I've had no issues with Netgear R7800 router which I purchased around the year 2016.
    It's a solid router, I've flashed Voxel on it many times, but ultimately kept the stock version due to stability.
  17. Vezeil
    Jun 2, 2020
    8
    It seems though that it's only the 5ghz which is broken, the router is running since the morning with good wired/2.4ghz WiFi connection. Waiting for Asus to give me a call tmrw.
    I do have a warranty for him so i'll probably get a replacment.
    Funny how the 5ghz LED is on even if i turn the leds off with the button.
  18. calvin tran
    calvin tran Occasional Visitor
    Mar 22, 2020
    24
    I just got mine from Amazon, and it's made in VN in 2020
  19. Vezeil
    Jun 2, 2020
    8
    And the 5ghz works fine?
  20. MarkyPancake
    MarkyPancake Senior Member
    Dec 17, 2013
    304
    I noticed yesterday that my 86U is a 2017 model. Apart from brief downtime when doing firmware update reboots, as a rough calculation, it's seen over 26,000 hours of service and counting.
