RT-ATX86U Latest firmware messed up AiMesh tab
Qbcd
Am I the only one having this issue? Since I last updated AX86U's stock firmware, whenever I go to the AiMesh tab, I get a text-only garbled page. That's usually pretty normal for the UI to happen occasionally and you just have to refresh and it's okay. But in this case, I keep refreshing and it doesn't get fixed. Eventually after 20 refreshes and/or waiting for a while and then returning to the page and refreshing again, it works and I get the normal graphical interface. But it's always a pain. I should say that I am using https, maybe on http this isn't a problem. With https it takes extra time to go through the menus and you get those graphical errors sometimes, I've learned to live with it, but this time with the AiMesh tab it's really messed up.
Anyone else experiencing this issue? I hope they fix it in the next update.
Most likely a web browser issue with your client. Try another browser or a phone app.
I had the same problem. Go back to whatever firmware you had before or at least 386 something. My node was going offline with 388 on both the AX86 and AX82. I've been a lot better on 386 for my AX82 but sometimes did just happen. So I might need to also go back on 386 for my AX86.
I have 3.0.0.4.388_22525 on AX86S and I don't have that problem, although I had it with previous versions of firmware.
Usually doing a Logoff or Ctrl + F5 would solve it.
