Tutorial Simple guide to using GitHub
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
L&LD
Part of the Furniture
@JGrana, I agree.
Is there a 10-step program/tutorial for GitHub navigation/comprehension? :)
thelonelycoder
@JGrana, I agree.
In three simple steps :)
Part one, the Overview
Navigate to my repository on GitHub: https://github.com/decoderman
Part two, the files
Part three, getting an idea what changes were made
Jack Yaz
dave14305
Something I have been better at doing is using the Releases properly: https://github.com/jackyaz/connmon/releases
This serves as a single point to see all changes made for a particular script/project without maintaining a separate changelog file.
And Github users can “Watch” the repository to be notified of new Releases when published. But notification only works if there is text in the Release, I believe.
doublehd
Part two, the files
Holy cow...........you guys are unbelievable,such a painkillers for me,thanks for both handy men.
L&LD
I gratefully appreciate all the contributions here! Everything helps.
@thelonelycoder's 3 step guide is a big start, but the 'what' or, more accurately the 'why' of what has changed or been fixed is still a black hole to me. I know I would need to learn to code to understand the nuances. I don't want to just be able to discern an extra space or a missed period (for example), I want to know how it affects the script from the perspective of the user.
@Jack Yaz's 'Releases' is much more user-friendly and more suited to the 'GitHub for Dummies' series types of books I can more readily relate to. :)
Of course, with the @thelonelycoder's method, I will eventually 'understand' more and more 'coding'. I would love to travel to that land and be able to order some cheese and wine by myself! :D
Keep up the splendid work gentlemen! Ignore the ramblings of an old member who once thought nothing could be harder than BASIC.
JGrana
Let me guess - second hardest was COBOL. ;-)
JT Strickland
I thought I was the only one who had difficulty gittin' around on github.
I appreciate all the help there already, but it would be good to have a bare bones tutorial for those greenhorns (like me) and explain things like, for instance, what is a Pull Request? I've decided that a Push is when the final version is released.
But don't spend any time on it. I don't see how you guys have any time at all with what all you do on the side as it is.
thanks again,
jts
thiggins
Mr. Easy
Staff member
There are many articles on this. Just search "git primer" or "github primer". If all you want is to grab a distro, you can just download a zip using the link found when clicking the Code button.
L&LD
@thiggins thanks for that suggestion.
However, most if not all of those are focused on programmers, not on users of the code...
thiggins
Mr. Easy
Staff member
What do "users of the code" need besides how to download a distro?
L&LD
They need to know what changes between versions.
They need to know what the changes that are made, affect them, and their usage.
They need to know if any assumptions of the script of the previous build has changed in the new code.
thiggins
Mr. Easy
Staff member
Those things are not a function of Git. They are up to the developer to document in release notes.
L&LD
That is why we need a thread here at snbforums.com that doesn't expire in 6 months. :)
RMerlin
Asuswrt-Merlin dev
A 6 month expiration does not prevent such a thread from existing. What you need rather is a developer willing to provide such a thread. I see lots of us here who seem to be doing just fine doing that for our respective projects.
L&LD
Actually RMerlin, it does.
Instead of one thread where we can check as we can, we now have to search for a needle in a haystack in multiple threads with very similar titles.
Unless the correct thread happens to be extremely active, it quickly falls to the wayside.
RMerlin
Asuswrt-Merlin dev
Set filter to desired addon. Find first post in the list coming from addon author. There, you're done.
If you find that more complicated than figuring out how to navigate around Github, then you must be missing something about how to use a public forum.
Bottom line is, nobody is preventing him from providing support threads here. He made a conscious choice not to do so. His call.
grifo
The new rule tax is not so much on the users as it is on the developers as they now have to watch multiple threads to provide support for their addons. Adam was replying to support questions and feature requests for Skynet almost every day which is one of the reasons the thread grew so big.
Doing that on a list of several threads is like having to go through a (messy) ticketing system queue on your spare and unpaid time. Some developers are prepared to do so (at least for now), others aren't and that's understandable. Adam decided to leave on the first day but others may follow later or reduce their contributions if they get tired or bored by too much admin work which most techies tend to loathe.
Since third party developers are an important factor of the success of the forum and the firmware I don't think it was a good idea to risk chasing them away for a rule that brings in a much smaller comparative value.
For the users the bigger problem is that now Adam is no longer around to provide support and possibly development for his addon.
Jack Yaz
It doesn't bother me. I do helpdesk support as my day job so this change doesn't faze me at all. You're all stuck with me!
