1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Skynet - Asus Firewall Addition
Discussion in 'Asuswrt-Merlin' started by Adamm, Apr 16, 2014.
  1. MisterGriffiths
    MisterGriffiths New Around Here
    Apr 12, 2018
    6
    I am seeing an unexpected output again when I run 'debug info':
    Skynet: [Complete] 46 IPs / 0 Ranges Banned. 0 New IPs / 0 New Ranges Banned. 0 Inbound / 4261 Outbound Connections Blocked! [debug] [1s]
    Any ideas why there would be so few IPs and zero Ranges blocked?
    Yesterday it was showing:
    [Complete] 110726 IPs / 1640 Ranges Banned. 0 New IPs / 0 New Ranges Banned. 898 Inbound / 0 Outbound Connections Blocked! [save] [7s]
  2. Adamm
    Adamm Very Senior Member
    Mar 26, 2013
    1,696
    You can run the banmalware function to repopulate it, ideally with one of the automatic updating options in the install menu.
  3. MisterGriffiths
    Apr 12, 2018
    6
    Thank you Adamm, is this something I need to run regularly? I am seeing this issue quite often and am not aware the issue has occurred until I log in and check the logs.
    Whenever I have installed Skynet, I have always chosen the recommended options which I believe does automatically update 'Malwarelist' Daily and also updates 'Skynet' Weekly.
  4. DonnyJohnny
    DonnyJohnny Very Senior Member
    Dec 17, 2017
    640
    It could be due to thumddive corruption or Low memory. I used to have this problem.
    Try do a fdisk on your thumddrive. Amtm have an option to install a check (fdisk) on router boot up.
    Make sure you have 512mb swap. If still can’t work, maybe try changing a new thumb drive.
  5. MisterGriffiths
    Apr 12, 2018
    6
    Ahh, ok, I have been running the amtm disk check script at boot and have just checked the log, I have this:
    Thu Jun 21 08:00:51 DST 2018 Unknown filesystem type on /dev/sda - skipping check.
    Is it possible to get some clearer instruction on how to prepare the external USB storage. I have used a few different types, including adapter fitted micro sd card. I am currently running an 8Gb thumbdrive with a 2Gb swapfile but it would seem I may not have prepared and formatted the thumbdrive correctly.
    I dont have anything running any linux, except for the router and a few RPIs.
    To format the thumbdrive, I unmounted it and ran this:
    mkfs.ext2 /dev/sda -L <label>
    Is there a better way than this or maybe ext2 is not correct?
  6. Adamm
    Mar 26, 2013
    1,696
    Thats a better discussion for the amtm thread where with enough searching you will find the answer to.
  7. MisterGriffiths
    Apr 12, 2018
    6
    Understood
  8. SanPe
    SanPe New Around Here
    Nov 6, 2017
    5
    France
    Hey!
    I'm running nginx on my Asus AC86U.
    Would it be possible for Skynet to ban IP getting a 403 or 401 error in nginx logs?
    If yes, how?
    alexandro likes this.
  9. punkinduster
    punkinduster Regular Contributor
    Dec 6, 2012
    104
    PA
    Question:
    I have debug temporarily set to off so once every hour Skynet is showing me the total number of blocks for inbound as well as outbound connections in the log file which is great. But when I look using the stats feature for the top ten in both directions it lists nothing in any of the outbound categories. It does list the inbound offenders. Do I need to change something to identify the outbound offenders or is the only solution to keep debug enabled all the time filling my log file?
  10. Adamm
    Mar 26, 2013
    1,696
    Skynet stats entirely depend on debug mode being enabled and working, no other way around it unfortunately.
  11. zyxmon
    zyxmon Regular Contributor
    Feb 9, 2015
    166
    Our installer is universal and cannot use platform specific files and folders. Our installers are here - https://github.com/Entware/Entware/wiki/Alternative-install-vs-standard
  12. AZDNice
    AZDNice Occasional Visitor
    Jun 11, 2018
    27
    I am fairly new at this but it seems that my skynet cannot restart due to a 'Lock File Detection'. Can someone assist me with this on how to rectify this situation please? Thank you in advance.
    https://i.imgur.com/GFd4Tyh.png
  13. Adamm
    Mar 26, 2013
    1,696
    As this error suggests, it should disappear within 20-60 seconds, was this the case?
  14. AZDNice
    Jun 11, 2018
    27
    @Adamm Sorry for just getting back to you. But I just checked now by opening Skynet, selecting 8 (to restart via AB) and got the same message. This has been way more than 60 sec. Should I uninstall and re-install? When I select (5) Skynet in AB-Solution it loads as if everything is fine but when I restart to ensure that it is running correctly this is the error I get. I don't know if I'm reading this correctly. Please lmk.
    https://i.imgur.com/5Dgbg4H.png
  15. Adamm
    Mar 26, 2013
    1,696
    You saw the message again because you restarted skynet. Skynet is working fine.
  16. AZDNice
    Jun 11, 2018
    27
    Thanks, still learning....never seen the error before. Thanks for your help.
  17. Mutzli
    Mutzli Regular Contributor
    Dec 22, 2014
    83
    Use r and not 8 to refresh the screen after 60sec. to display the menu again and the error should be gone.
  18. elnash
    elnash Occasional Visitor
    Dec 15, 2016
    49
    Spain
    Good, a newbie question. skynet works with IPv4 ?? Thanks in advance. regards!!!
  19. popxunga
    popxunga Occasional Visitor
    Sep 19, 2015
    44
    IPSet v6 and IPv6 are not the same thing.
    Skynet supports IPv4.
    Skynet doesn't support IPv6.
  20. elnash
    Dec 15, 2016
    49
    Spain
    Ok, thanks for the clarification.
