(I hope you don't mind that I copied this post from my thread on LTT since I really want to get help on this)
Hello everyone!
I have been having this problem and not sure when it started but it has been at least a year since I started noticing it.
We have a small home network with 2 PCs (desktop and laptop) that are both connected to a router (Asus RT-N66U) through wireless and ethernet respectively and the router is connected to the internet modem through ethernet cable too. The laptop is a Dell Inspiron N5010 (i3-350M, 4GB, DW1501 Wireless-N WLAN Half-Mini Card) and even though the card is n I was never able to get speeds higher than 3.5MB/s when I was uploading files to the laptop from my desktop PC (forgot to mention the laptop's signal & noise averages -20dBm and -90dBm). But the speed is not the problem.
The weird thing is that the speed when I take files from the laptop to desktop is solid around 3.5-4MB/s but when it's the opposite the speed is barely a crawl 1-5KB/s, overall the connection basically freezes up for like 5 seconds before any action when thing are getting moved to the laptop. But again, when files are taken from the laptop is all well and good.
I'm pretty sure it's the laptop's fault because I have upgraded my router 4 months ago and I had the exact same situation. I have updated to the latest wireless drivers a few days ago and it was working fine until the laptop got restarted. I used to change some options in the wireless card properties (Advanced tab) and it started working at 3+MB/s again but as soon as you restart the laptop it's back to a crawl.
I can't figure out why is uploading files to the laptop is so slow (while at the same time downloading from it is working fine).
Thanks in advance guys.
Hello everyone!
