[ SOLVED ] Can't remove file in /jffs
octopus
Part of the Furniture
Hi
I have a strange problem, can't remove file in /jffs. I have renamed one file and I got a "´" in file name.
Tried to remove/delete with winSCP and rm -f with no succes also formated /jffs but no new formated /jffs.
Have not yet tried to do a reset router with "wps" button.
Someone have any suggestion to remove that file?
on´_hold_vsftp.postconf
If the file is actually called "on´_hold_vsftp.postconf", log onto the router using something like PuTTY and try using the following commands:
# cd /jffs
# rm -f *vsftp.postconf
# cd /jffs
Really good propostion.
Or you can try to quote it
rm "on´_hold_vsftp.postconf"
or
rm "./on´_hold_vsftp.postconf"
Or escape it
rm on\´_hold_vsftp.postconf
or
rm ./on\´_hold_vsftp.postconf
P.S. Via ssh or web cmd interface (if it is still available)
# cd /jffs
Yes its have that name
Thank you
I try later on I'm out atm.
Back in stone-age DOS days,
del *vsftp.postconf
would delete ALL files in the directory, which had the extension ".postconf ". The "vsftp" part would have been totally ignored. (It was documented in the DOS 2.0 manual, but rather hidden away.)
I once used a command line as above, wiped the directory clean, and for a few hours I thought I was going to be fired. I never made the same mistake again :-)
I am not a scripting expert and maybe *nix scripts work differently, but since this is the only file whose name starts with "on", maybe it would be safer to use
# cd /jffs
# rm -f on*.postconf
del *vsftp.postconf
I once used a command line as above, wiped the directory clean, and for a few hours I thought I was going to be fired. I never made the same mistake again :)
# cd /jffs
Thank you
This did the trick. Tested all other suggestions without delete on file.
Thank you all for helping hand.:)
