Diversion [Solved] Got "67" error when trying to send mail from Diversion
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
sn2018
Just setup Diversion and configured it to send email with a Google email address When I try the test email, I got
curl: (67) Login denied
The settings is in the attached file. Is there some other settings I need to add?
RMerlin
Asuswrt-Merlin dev
By default Google will refuse plain AUTH, and require the use of OAUTH. You will need to configure your account to allow "less secure" logns.
Wallace_n_Gromit
amplatfus
Mine is configured like this. I created a app password into google account for this.
  1. Edit From address:   i.e.: [email protected]
  2. Edit To name:        your desired name
  3. Edit To address:     [email protected]
  4. Edit Router name:    choose it
  5. Edit User name:      [email protected]
  6. Edit Password:       your password
  7. Edit SMTP Server:    smtp.gmail.com
  8. Edit Server port:    465
  9. Edit Protocol:       smtps
 10. Edit SSL flag:       Set to --insecure if curl problems occur
 11. Send testmail to confirm settings
I receive a warning: deprecated key derivation used. Using -iter or -pbkdf2 woud be better. (warning.png attached)
But is working (inbox.png attached).
Good luck,
amplatfus
sn2018
Good luck,
amplatfus
Thank you. My problem was using the real email address on 1 and "fake" name on 5. Reverse the 2 fixed it.
elorimer
You can add those to the diversion scripts that call the password. It is in several places. Note that you have to add it to the script that encrypts the password too, as it has to be encrypted and de-encrypted the same. I think it is on @thelonelycoder's to do list, but the transition isn't simple. It isn't really a high priority, because security isn't the point here, it is handling weird passwords.
