Entware Mailx installation
deveals
Hello and good day! Attempting to create performance monitoring scripts/reports and would like to forward output as a SMTP email attachment using MailX:
echo "Test email body text" | mailx -s "Test email subject" -a output.txt someone@gmail.com
Recieving the following error message:
/opt/sbin/sendmail: No such file or directory
Searched/located sendmail
find / -name sendmail
/usr/sbin/sendmail
As a test, I copied /usr/sbin/sendmail to /opt/sbin/sendmail .. SMTP email attempt failed again:
cp /usr/sbin/sendmail /opt/sbin/sendmail
echo "Test email body" | mailx -s "Test email subject" -a output.txt someone@gmail.com
send-mail: applet not found
rm /opt/sbin/sendmail
SMTP email test via amtm is successful; SMTP email test using basic sendmail is also successful but unable to specify subject, add body text, and attach file (all needed).
In advance, your consideration and suggestions are appreciated.
As mailx is looking for the Entware version of sendmail (postfix) it might be easiest if you just install that.
Hello! Prompt review and suggestion appreciated! As suggested, I installed postfix and located the following:
find / -name sendmail*
/tmp/mnt/sda/entware/sbin/sendmail.postfix
I retried the mailx command and the error continues ... should I try:
1. copying /tmp/mnt/sda/entware/sbin/sendmail.postfix to /opt/sbin/sendmail (know how)
2. linking /opt/sbin/sendmail to /tmp/mnt/sda/entware/sbin/sendmail.postfix (don't know and requires research)
3. something else
