TLDR; Set up gateway in bridge mode. Connect node with cable in second LAN port. Wifi Internet is now inaccessable, clients keep connecting/disconnecting constantly, and app does not work (won't find product). All okey again as soon as I disconnect cable. Why?
Long version: I needed to get wifi up to my roof terrasse, and bought this stupid product.
Regardless of where I put any wireless AP inside, the signal will be visible for clients on the roof, but it will either provide no data at all, or max 1Mbit.
I have ethernet cable up there, so I was thinking, should be easy to just connect a node up there, and I will have a Wifi signal that just works everywhere without worry about stupid clients (looking at you iPhone) who won't switch automaticallly to the strongest signal. I already tried a cabled repeater, but clients will usually hang on to weakest signal instead of just connecting to a stronger one (why!?)
So I bought this cheap mesh thing, and it turns out connecting node via ethernet is not a documented feature (despite being advertised on their product site!), and I had to read this thread to even find out how to do it. Only way was to set gateway up with cable in port 1. When setup, switch to bridge mode, and move cable to port 2. Then connect node with cable in it's port 2.
But problem is, as soon as the node is connected to the switch, the entire Wifi network seems to crash. iPhone constantly disconnecting, and if it stays connected, internet will not work, and neither will the Tenda app - it will say It can't find any networks.
I spent all day replacing the ethernet cable, because I was sure that was the problem. It was not.
So does anyone have any idea what could be wrong?
