RMerlin
Asuswrt-Merlin dev
Hey folks,
There's a lot of different scripts appearing lately, allowing users to implement advanced firewall-level filtering. This is great
A lot of those require being added to the firewall-start script, and I understand that things can start getting messy, as everyone probably does it his way, and that file could potentially become cluttered.
I would recommend agreeing on some kind of "standard" way of dealing with firewall-start. Here are my recommendations:
First, limit the changes to firewall-start to either a single line, two at most. One (optional) line could be a comment to simply identify the next line.
The second line would be a call to a separate script, which would contain ALL of the changes you want to make at firewall-start launch.
This way, it will make it easier to detect the presence of a given script, and also to handle it. Here's an example.
Let's say your script comes with its own install/uninstall routine. The install routine would insert the following line:
Then, later on, the user wants to uninstall your script. Your uninstaller can then simply remove that one single line, using sed (you can even use the helper.sh script that I include in the firmware, and which can easily remove/add/replace a line in a given file):
Similarly, you can easily detect if another script is present, and deal accordingly if you can find that specific line inside firewall-start: warn the user of compatibility issue, insert yourself specifically before that line, etc.... Use something like sed or grep to detect the presence of the other script within firewall-start.
In the end, this will make it easier for the developers, but also for the users (making it easier/simpler to implement an uninstaller).
sh /jffs/yourscript/start-superfilter
#Uninstaller
pc_delete "sh /jffs/yourscript/start-superfilter" "/jffs/scripts/firewall-start"
rm -rf /jffs/yourscript
service restart_firewall
