1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Tools_Sysinfo page and correct WAN LAN show
Discussion in 'Asuswrt-Merlin' started by AndreyPopov, Jul 29, 2014.
  1. AndreyPopov
    AndreyPopov Senior Member
    Jun 28, 2014
    287
    Ukraine
    1. AC87 have 7 port for CPU - in Tools page logic only port 8 and 5 sutiable to CPU
    2. others routers have different formulas of cpu/WAN/LANs
    case MODEL_RTAC87U:
    WAN L1 L2 L3 L4 CPU */
    0, 5, 3, 2, 1, 7 };
    case MODEL_RTN66U:
    case MODEL_RTAC66U:
    { 0, 1, 2, 3, 4, 8 }; }
    case MODEL_RTN16:
    { 0, 4, 3, 2, 1, 8 };
    case MODEL_RTN15U:
    { 4, 3, 2, 1, 0, 8 };
    case MODEL_RTN10U:
    0, 4, 3, 2, 1, 5 };
    case MODEL_RTAC56U:
    case MODEL_RTN14UHP:
    4, 0, 1, 2, 3, 5 };
    case MODEL_RTAC68U:
    case MODEL_RTAC3200:
    case MODEL_RTN18U:
    case MODEL_RTAC53U:
    0, 1, 2, 3, 4, 5 };
    case MODEL_RTN53:
    case MODEL_RTN12:
    case MODEL_RTN12B1:
    case MODEL_RTN12C1:
    case MODEL_RTN12D1:
    case MODEL_RTN12VP:
    case MODEL_RTN12HP:
    case MODEL_RTN12HP_B1:
    case MODEL_RTN10P:
    case MODEL_RTN10D1:
    case MODEL_RTN10PV2:
    4, 3, 2, 1, 0, 5 };
    RMerlin please help correct code in Tools page for correct show WAN and LANs
    P.S. for ac87U now code already corrected.
  2. AndreyPopov
    Jun 28, 2014
    287
    Ukraine
    switch (based_modelid) :
    		case RT-AC87U :
    			tmpPort = ???
    			port = ???
    			entry = ????
    			code_ports = ???
    		break;
    		case RT-AC66U :
    		case RT-N66U :
    			tmpPort = ???
    			port = ???
    			entry = ????
    			code_ports = ???
    		break;
    		case RT-N16 :
    			tmpPort = ???
    			port = ???
    			entry = ????
    			code_ports = ???
    		break;
    		case RT-N15U :
    			tmpPort = ???
    			port = ???
    			entry = ????
    			code_ports = ???
    		break;
    		case RT-N10U :
    			tmpPort = ???
    			port = ???
    			entry = ????
    			code_ports = ???
    		break;
    		case RT-AC56U :
    		case RT-N14UHP :
    			tmpPort = ???
    			port = ???
    			entry = ????
    			code_ports = ???
    		break;
    		case RT-AC68U :
    		case RT-N18U :
    		case RT-AC3200 :
    		case RT-AC53U :
    			tmpPort = ???
    			port = ???
    			entry = ????
    			code_ports = ???
    		break;
    		case RT-N53 :
    		case RT-N12 :
    		case RT-N12A1 :
    		case RT-N12B1 :
    		case RT-N12C1 :
    		case RT-N12D1 :
    		case RT-N12HP :
    		case RT-N12HP_V1 :
    		case RT-N12VP :
    		case RT-N10P :
    		case RT-N10P_V2 :
    		case RT-N10D1 :
    			tmpPort = ???
    			port = ???
    			entry = ????
    			code_ports = ???
    		break;
  3. AndreyPopov
    Jun 28, 2014
    287
    Ukraine
    may be code:
    			if (tmpPort == "8") {		// CPU Port
    				continue;
    			} else if (based_modelid == "RT-AC56U") {
    				tmpPort++;		// Port starts at 0
    				if (tmpPort == "5") tmpPort = 0;	// Last port is WAN
    			} else if (based_modelid == "RT-AC87U") {
    				if (tmpPort == "4")
    					continue;	// This is the internal LAN port
    				if (tmpPort == "5") {
    					tmpPort = "4";	// This is the LAN 4 port from QTN
    					devicename = "<unknown>";
    			if (tmpPort == "0") {
    				port = "WAN";
    			} else {
    				if ((based_modelid == "RT-N16") || (based_modelid == "RT-AC87U"))  tmpPort = 5 - tmpPort;
    				port = "LAN "+tmpPort;
    with this
    		case RT-AC87U :
    		  switch (tmpPort) :
    			  case 0 : port = "WAN";
    			  case 1 : port = "LAN 4";
    			  case 2 : port = "LAN 3";
    			  case 3 : port = "LAN 2";
    			  case 5 : port = "LAN 1";
    			  case 4 :
    			  case 6 :
    			  case 7 :
    			  case 8 :
    			break;
    		break;
    		case RT-AC66U :
    		case RT-N66U :
    		case RT-AC68U :
    		case RT-N18U :
    		case RT-AC3200 :
    		case RT-AC53U :
    		  switch (tmpPort) :
    			  case 1 : port = "LAN 1";
    			  case 2 : port = "LAN 2";
    			  case 3 : port = "LAN 3";
    			  case 4 : port = "LAN 4";
    			  case 5 :
    			  case 6 :
    			  case 7 :
    			  case 8 :
    			break;
    		break;
    		case RT-N16 :
    		case RT-N10U :
    		  switch (tmpPort) :
    			  case 4 : port = "LAN 1";
    			  case 5 :
    			  case 6 :
    			  case 7 :
    			  case 8 :
    			break;
    		break;
    		case RT-N15U :
    		case RT-N53 :
    		case RT-N12 :
    		case RT-N12A1 :
    		case RT-N12B1 :
    		case RT-N12C1 :
    		case RT-N12D1 :
    		case RT-N12HP :
    		case RT-N12HP_V1 :
    		case RT-N12VP :
    		case RT-N10P :
    		case RT-N10P_V2 :
    		case RT-N10D1 :
    		  switch (tmpPort) :
    			  case 4 : port = "WAN";
    			  case 0 : port = "LAN 4";
    			  case 1 : port = "LAN 3";
    			  case 3 : port = "LAN 1";
    			  case 5 :
    			  case 6 :
    			  case 7 :
    			  case 8 :
    			break;
    		break;
    		case RT-AC56U :
    		case RT-N14UHP :
    		  switch (tmpPort) :
    			  case 0 : port = "LAN 1";
    			  case 1 : port = "LAN 2";
    			  case 3 : port = "LAN 4";
    			  case 5 :
    			  case 6 :
    			  case 7 :
    			  case 8 :
    			break;
    		break;
  4. RMerlin
    RMerlin Super Moderator
    Apr 14, 2012
    31,818
    Canada
    You're replacing 19 lines of code with 110 lines. With an interpreted language such as Javascript, this isn't very efficient.
  5. AndreyPopov
    Jun 28, 2014
    287
    Ukraine
    more lines of code - I agree
    but this code for 5 port models and more than 10 router models
    your code have 8 if's to find what port wan or lan.
    I think {switch ... case} may be faster in this situation, imho
    I only ask your opinion.
    thanks
  6. AndreyPopov
    Jun 28, 2014
    287
    Ukraine
    like for me - work perfect:
    //Andrey begin
    		case "RT-AC87U":
    		  switch (tmpPort)
    			  case "0":
    				port = "WAN";
    				break;
    			  case "1":
    				port = "LAN 4";
    				break;
    			  case "2":
    				port = "LAN 3";
    				break;
    			  case "3":
    				port = "LAN 2";
    				break;
    			  case "5":
    				port = "LAN 1";
    				break;
    			  default:
    				port = "CPU";
    		break;
    		case "RT-AC66U":
    		case "RT-N66U":
    		case "RT-AC68U":
    		case "RT-N18U":
    		case "RT-AC3200":
    		case "RT-AC53U":
    		  switch (tmpPort)
    			  case "0":
    				port = "WAN";
    				break;
    			  case "1":
    				port = "LAN 1";
    				break;
    			  case "2":
    				port = "LAN 2";
    				break;
    			  case "3":
    				port = "LAN 3";
    				break;
    			  case "4":
    				port = "LAN 4";
    				break;
    			  default:
    				port = "CPU";
    		break;
    		case "RT-N16":
    		case "RT-N10U":
    		  switch (tmpPort)
    			  case "0":
    				port = "WAN";
    				break;
    			  case "1":
    				port = "LAN 4";
    				break;
    			  case "2":
    				port = "LAN 3";
    				break;
    			  case "3":
    				port = "LAN 2";
    				break;
    			  case "4":
    				port = "LAN 1";
    				break;
    			  default:
    				port = "CPU";
    		break;
    		case "RT-N15U":
    		case "RT-N53":
    		case "RT-N12":
    		case "RT-N12A1":
    		case "RT-N12B1":
    		case "RT-N12C1":
    		case "RT-N12D1":
    		case "RT-N12HP":
    		case "RT-N12HP_V1":
    		case "RT-N12VP":
    		case "RT-N10P":
    		case "RT-N10P_V2":
    		case "RT-N10D1":
    		  switch (tmpPort)
    			  case "4":
    				port = "WAN";
    				break;
    			  case "0":
    				port = "LAN 4";
    				break;
    			  case "1":
    				port = "LAN 3";
    				break;
    			  case "2":
    				port = "LAN 2";
    				break;
    			  case "3":
    				port = "LAN 1";
    				break;
    			  default:
    				port = "CPU";
    		break;
    		case "RT-AC56U":
    		case "RT-N14UHP":
    		  switch (tmpPort)
    			  case "4":
    				port = "WAN";
    				break;
    			  case "0":
    				port = "LAN 1";
    				break;
    			  case "1":
    				port = "LAN 2";
    				break;
    			  case "2":
    				port = "LAN 3";
    				break;
    			  case "3":
    				port = "LAN 4";
    				break;
    			  default:
    				port = "CPU";
    		break;
    //Andrey end
    			if ( port !== "CPU") {
    			entry = '<tr><td>' + port + '</td><td>' + (line[7] & 0xFFF) + '</td><td><span>' + state2 + '</span></td>';
    			entry += '<td>'+ devicename +'</td></tr>';}
    			else break;
    tested on RT-N15U. now try on others RT-N10U and RT-N10P
    P.S. and this code ready for future router models and switch ports models. ;)
    P.S.P.S. I don't understand for what this code?
    			if (based_modelid == "RT-N16")
    				code_ports = entry + code_ports;
    			else
    				code_ports += entry;
    for what you add space (" ") for entry var if RT-N16?
