I'm about to have Sonic.net install their Sonic Gigabit Fiber in my house in a few weeks as they are now offering this in some districts of San Francisco.
So I need a new Route with gigabit WAN connection.
Based upon the my devices and their capabilities, an AC1750 type Gigabit Router will meet my needs.
The top 3 ranked AC1750 routers on SNB are:
Also in the same price range (up to about $120) SNB has the following AC1900 routers:
I need it to cover just one floor of a fairly small house (1500 sq.ft. 25' x 60') where the router would be located at one end of the 60' but in the middle of the 25' width.
I'm hoping that since these 6 routers have been around for a while, they should have reached a firmware level that is very stable (if they are ever to reach a stable version).
Also trying to find one that stands a higher chance of not getting a lemon upfront as I'm trying to avoid the RMA process. I figure if its bad or dead right from the start I can send it back to Amazon but if I start having problems after the first 30 days then I'll have to deal with the manufacturer.
I'm concern about the RMA process with the manufacturers after reading a couple of reviews on TP-Link RMA. I've been fortunate so far of never having to send a unit back to the manufacturer and I'm not sure if any of them (TP-Link, Linksys, or ASUS) stands out as a lot better in their customer service for RMA's than the other ones.
Any one or two of these 6 routers that really stand out to you that you strongly recommend (and any manufacturer that stands out in terms of support and handling RMA units?)
thanks in advance for any recommendations/feedback you can provide.
TP-Link Archer C8, ASUS RT-AC66U, TP-Link Archer C7 (ranked #1, #2, #3 respectively)
Linksys EA6900 / TP-Link Archer C9 (ranked #3, #8 respectively)
so I'm open to buying one of them if one of them stands out even better than the AC1750's.I need it to cover just one floor of a fairly small house (1500 sq.ft. 25' x 60') where the router would be located at one end of the 60' but in the middle of the 25' width.
