i have AX86U thinking about buying tp link
yamin2000
Hi
TP-Link Deco XE75 AXE5400​
OR
EnGenius EWS357-FIT WiFi 6 AX1800 2x2​
I do not care about asus software all i care about good wifi range ,or just buy 2 asus ai mish ?but it will cosr more than above devices
Hi
OR
If you like your AX86U and need more coverage, an option would be to keep it as a wired AiMesh node and add a new main router like the AX86U Pro or AX88U Pro.
If you buy new kit and it's going to be wireless, you may want a third band dedicated to the wireless backhaul for better performance... not shared with client connections.
OE
EnGenius EWS357-FIT
This EnGenius model is an access point only. It needs a router and a wired connection.
What will work better in your place is unknown. Region and Wi-Fi environment specific.
