jamesnmandy
Hi all first post. Yes I have been searching and aparrently the issue I am having isn't commonly inquired about.
I consider myself more competent than the casual home user capable of and having flashed multiple WRT54G routers with DDWRT and configuring a relatively crowded home network with static IP's and port forwarding and such. Also have an adequate HTPC with XBMC(Kodi) and such streaming content from a NAS.
I have been lurking and reading articles here for a number of years, hence the reason I went out of my way to find a used WNDR3700 v1 router which was my first "decent" router after years of using whatever 25-50 dollar router I could get cheap at best buy or walmart because a "router is a router" right? Haha. Thanks to this site as a resource I learned to purchased a decent quality router and my 3700 is still going strong... sort of... .
Now here is my situation. I used to never have to reboot this router (running stock netgear firmware). Now it seems every couple weeks or so the wireless connection gets "saturated" kinda like the old cheap routers would get after a day and a reboot sorts it out.
We also recently got a new 4k hdr TV and PS4 Pro which are on the wireless 5G channel.
I also have several laptops/tablets/phones on WiFi. Also my wired connections are fully maxed and I am actually wishing I had 8 ethernet ports since I could wire the TV and ps4 along with the Netgear Ready NAS(old RND4000v1 sparc model with 1gb ram uograde) , bluray player, Home theater PC, and Tivo cable box and a desktop.
That being said the old WNDR3700 is holding up well as it is capable of providing a maxed out 60 megabit Internet service from my phones(using speed test) and it is streaming 4k HDR content from Netflix, Amazon Prime, and YouTube with no buffering.
This all being said.... I am trying to figure out what to do. I am really fond of the out of the box Netgear products so far.
A. Get a netgear switch and add behind the netgear router and deal with occasional reboots?
A.1? Flash this WNDR3700 with custom firmware that may help that situation? I suspect the router is just getting "tired" since the change appears to be progressive which would indicate hardware not firmware to me.
B. Get a new AC class router to minimize reboots/slowdowns? Is there even any benefit here since the current router can already handle the bandwidth demands?
C. Get an 8 port AC class router? I have like 2 models to choose from from what I have seen and they are far more expensive than I care to invest if they will effectively not A. provide a faster connection to the Internet and B. cost far more than adding a switch to existing router...
Why even upgrade from N to AC if range is not an issue (almost all devices are in home entertainment center literally feet apart) and the N router can already max out my 60mbps Internet?
Sorry so wordy. Thanks in advance for your input.
