bushwacked
Hello,
I had the XT12 dual node setup, 1 went to crap so ASUS replaced it with 2 ET12's because XT12s were out of stock and they said it would be a month + ... Obviously I did not want to wait that long, so I downgraded.
However, before I wiped the XT12 that was setup as the router, I tried to add 1 of the ET12s as a node, it found, but failed 5 times in a row adding it at about 20-25% mark. Just popped up a general error of could not connect or whatever, nothing really to go on. So, in the time crunch I was in to get the house wifi back up and running, I installed the ET12's, however this time when I try to at the XT12 node to the mesh, it does not even find it.
So my question is ... should these 2 systems not be able to find each other and run as nodes on the network? I would assume the XT12, being the more higher end of the 2, should be able to find and let the ET12's connect, but that was not the case.
