TopDownRide
So I was all excited about the Portal (it's in my Amazon cart) until I read your - very thorough - review.
I live in a condo & all my important devices are located in the open living area (one of those open-space kitchen/breakfast room/office nook/living room combos with sliding glass doors to a lanai serving as the only windows along the south wall).
Unfortunately, the Comcast tech insisted on connecting the main coax cable line outside, the one feeding my service, to the outlet next to my 11 yr old iMac in the 'office nook' corner of the open living area instead of the outlet next to the 4K UHD Smart TV where I need the speed.
I have a 150mbps ISP plan and my own equipment which although new, I'm looking to change because I'm having speed issues on the tv where I need the speed to stream, especially 4K (I don't have cable tv). On the 5GHz wifi network, I'm getting 179mbps on all my devices, even on my 2006 iMac running Lion, but the TV struggles to pull 12-30mbps. I just had Vizio replace all internals on the tv (it's brand new) because they insisted I should be getting at least 100mbps on my plan (new network card, motherboard, 4K module, etc.). Didn't help. Stumped the tech who was also a networking expert. Wired speeds are basically the same - I can't get more than 31mbps even wired.
I have an Arris sb6183 cable modem (16 down/4 up) although my ISP has 24 bonded down and an Apple AirPort Extreme for the router with the 5GHz network enabled with a unique SSID.
I haven't seen any issues with my wifi coverage but I've definitely had a lot of evidence that I'm having QoS, network fairness, and bandwidth allocation issues. Often, only one device at a time will get the 'fast' speeds of 179mbps and the others will test like this: device #1 = 179mbps, device #2 = 100mbps, device #3 = 70mbps, device #4 = 25-30mbps, device #5 = 7-12mbps, and device #6 = 1mbps.
The only thing that changes is which devices are #1, 2, 3, 4....etc., and the TV, wifi or wired, NEVER changes other than sometimes getting a 10-20mbps increase from wifi to wit4d but it never ever reaches 32mbps or above.
My area, especially due to the condo, is heavily congested with routers and SSIDs and the Comcast Xfinity Gateways hosting xfinitywifi hotspots. It's one of the reasons I chose the Apple AirPort Extreme and it's 5GHz weather band capability.
But there's something wrong. It's either some conflict with my ISP signal and the equipment or between my router and my cable modem, that I have the wrong cable modem for my setup/needs, that there's a problem with my router, not having QoS/bandwidth allocation mgmt/network fairness/etc. features, or that the TV is just flat out incapable of 100mbps despite having everything replaced.
I need blazing fast wireless speeds at least on the 5GHz network for my 4K Smart TV, my NVidia Shield Pro, running Plex & the NAS, using a Chromecast Ultra, and the new Apple TV 5th Gen (4K) when it comes out .....all to stream 4K both from sources like Netflix, Amazon, YouTube, VUDU, UltraFlix, etc., and also blu-ray 4K UHD rips.
All of that WALL of text to ask you .... what do you think about the Portal vs the Netgear Nighthawk X4S and what do you make of my situation/problem? I was really settled on the Portal and buying the 32 down/8 up DOCSIS 3.1 Arris sb8200 when it's back in stock until I read your article. Now, I'm wondering if the Nighthawk X4S is the best router for me? Thanks for confusing me, lol
