I prefer to use DHCP reservations (aka Manually Assigned) - Some devices I set static IP on the device, others I do not.
Do I need to ensure the DHCP Pool settings, in the ASUS, cover the Manually Assigned address range also - os will the router properly handle IPs that I set in the Manually Assigned section, even if they are not in the DHCP Pool range?
My ultimate goal is to force all new clients into a very small range... .245-254 so I can limit any rogue connections and also quickly identify them.
thx
thx
