I got a Klein Tools VDV526-100 cable tester. It indicated a miswire. I replaced both cable ends. The miswire light went out, but now the tester's "open" indicator is illuminated. I replaced the connectors multiple times and cannot resolve the open problem. I am using a ratcheting crimping tool to attach the rj45 connectors. to the cable, and am aligning the wires in the 568b order. I have successfully put connectors on cables in the past, so even if I had made an error, with the multiple connectors I tried on this cable, I should have gotten it right at least once. Also, as a test, I ran a temporary cable and the AIMesh node shows the full 350-370 Gbps speed that the main router has.
If anyone has any ideas about the open fault I get now that I did not have before I replaced the connectors and how to resolve it, I would be happy to read your ideas. I plan on running a new cable this weekend. The cable goes through exposed basement joists and up to an unfinished attic area, so it will not be too bad of a job.
