1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
AiProtection in 384.5 work or no?
Discussion in 'Asuswrt-Merlin' started by WarIock, Jun 21, 2018.
  1. WarIock
    WarIock Occasional Visitor
    May 17, 2016
    11
    AiProtection in 384.5 work or no? After update to 384.5 one month ago no new events on AiProtection page.
    Vexira likes this.
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. JacquesR
    JacquesR Regular Contributor
    Feb 3, 2014
    63
    Works fine for me.
    Vexira likes this.
  4. WarIock
    May 17, 2016
    11
    I have 0 hits in all puncts for a month. Please show me your malicious sites blocking list. I try to visit these sites to check protection works.
    Vexira likes this.
  5. Vexira
    Vexira Very Senior Member
    Jan 20, 2017
    1,393
    Australia
    Mine works fine did you enable all the features?
  6. WarIock
    May 17, 2016
    11
    Sure. Before update from previous version, i had external attacks every day. After update i cleared all events and hit, and now I still have 0 hits. I I have tried to restart aiprotection from web interface, and from ssh. Please show me your malicious sites blocking list. I try to visit these sites to check protection works.
  7. JacquesR
    Feb 3, 2014
    63
    The most recent one I have is for whirlweath.com - but maybe you're on to something, as that was on May 22. I can't recall when I installed 384.5, though (and I'm also running Skynet).
  8. Nigel Jones
    Nigel Jones Regular Contributor
    May 23, 2017
    104
    I've been getting two way ips hits throughout.. and now on the alpha too. Malicious yes blocking more sporadic and b nothing since 13 June but I've had week long gaps before
  9. WarIock
    May 17, 2016
    11
  10. XIII
    XIII Very Senior Member
    Feb 27, 2014
    601
    For me two-way IPS has been empty for all recent 86u firmwares.
    Family members do get hits on 56u and 68u.
    However, it’s probably not the model, but something else that causes this. No clue what...
  11. slobodan
    slobodan Regular Contributor
    Jul 30, 2015
    124
    I have two AC56U, there are no hits. I have to say that both score a Perfect TruStealth at grc.com. So, I have opened no ports on the firewall and UPnP is off.
  12. Sinner
    Sinner Senior Member
    Sep 30, 2017
    289
    Canada
    On my 3100 ive never had any hit u till 384.5. Since installing ive had 9 blocked malicous sites related to adsense or something. I havent done anything differently. If i had to guess it didnt work before 384.5 but works now for me at least
  13. Crazy
    Crazy Occasional Visitor
    Jul 20, 2013
    19
    You can use the link below to test your AiProtect. Before when I was jumping around with firmware to test I found aiprotect broken and will not have any events. Only way was to reset router to factory and manually enter all settings.
    https://www.wicar.org/test-malware.html
  14. WarIock
    May 17, 2016
    11
    I checked this problem. The protection works, but no new hits and no log events do not appear until the e-mail notification is not used. If I enable e-mail notification for this protection, then all hits and events, including those that occurred before, are displayed correctly.
  15. Sinner
    Sep 30, 2017
    289
    Canada
    that is strange.. I unfortunately don't have gmail and have never been able to use the email notification and mine works fine.
  16. Figaro
    Figaro Occasional Visitor
    Nov 7, 2016
    19
    CNY
    Add me to those who no longer see new AiProtection events after updating to 384.5. Previously on 384.4_2 I was getting daily hits for "Malicious Sites" and "Two-Way IPS". RT-AC68P Router with email notifications turned off.
  17. skeal
    skeal Part of the Furniture
    Apr 30, 2016
    2,006
    /etc
    AiProtection working fine here with lates alpha on ac3100.
  18. clvk07
    clvk07 Regular Contributor
    Oct 13, 2012
    182
    I have the same problem. I think it started with 384.4,... Using AC88U... Protection seems to work but no hits. I think also email alerts are not working
  19. Figaro
    Nov 7, 2016
    19
    CNY
    Update: A few days ago I turned on email alerts and now I am seeing hits. However, I have yet to received any emails.
  20. Sinner
    Sep 30, 2017
    289
    Canada
    I get email alerts in 384.5 but its hit n miss... almost as though it either delays and bunches several together or only send an email once until another type of block has occurred.. possibly to avoid email spamming.. not sure yet but it is working.
  21. BuTTuS
    BuTTuS Occasional Visitor
    Dec 7, 2012
    48
    My feeling is that it’s depending on the signature version. Right now on version 2.078 I get nothing, but on the previous one I got a lot.
    Emails have never worked for me.
