Combat Goat
First, to preempt the inevitable "nut up and run cable" comment, believe me, I have looked into that option thoroughly (as well as others) before arriving where I am. However, I am dealing a 1940's construction that has a lot of brick/masonry, and while the home mostly well restored, the wiring leaves a lot to be desired. For instance, I have observed a mix of old and new Romex, and even (legacy) knob and tube, and then I won't even get into the CableTV/DirectTV coax mess (prior owner). Salient points: Three levels, brick/masonry, and obstacles to optimal WiFi, despite that total square footage is relatively modest (perhaps 2500 or so).
The fiber entry point is in the basement, which is also the nerve center for Linux Server, NAS, Workstation, switch, and (currently) RT-AC68U, and there are three levels total (basement, main/living, top/sleeping). The RT-AC68U does a commendable job, notwithstanding obstacles, of supplying weak 2ghz coverage from the basement to top floor. Also, I should add, the entire point of this is that my wife's office is up there, though I do have a PS4 and some other media devices there too, but the emphasis is wife's office. She is a resident physician, likes to walk around freely with a tablet or laptop while working, and when she inevitably experiences a dropped connection while in the middle of something, I hear about it, and I am rather over it. For my part, the nerve center is fully wired, so top floor WiFi saturation is just about getting her squared.
As noted above, my wife is a medical resident, we bought this place always knowing we wouldn't own it long, and we will probably sell in about two years or so, so infrastructure investments really need to have a rather direct translation to equity if I am going to throw money at something, and while going fully wired with UniFi AP's in the proper locations like cute little light fixtures probably meets that description, there are serious obstacles due to the type of construction, the between the APs, a new switch to manage them, the wiring, labor, tools, and so forth, it's just a bigger project than I want to take on. Meanwhile, the AmpliFi does saturate the house with WiFi, it does so for about $300, and I can always cart it off or sell it if I want. However, I did do a double run of Cat6 cable (had 100 feet of it on hand already), from a central location in the house to the right of our TV (mounted above fireplace on our second level), down to the basement, then tacked along the baseboards over to the fiber entry point, which is where the shelf for the RT68U, switch, and NAS is, then terminated the endpoints into keystone boxes which match aesthetics. Modest project.
Currently, I have the AmpliFi HD on a table that sits near/above the keystone box on the second level, and I have one Cat 6 patch cable connected to the WAN on the AmpliFi HD. If you are wondering why two cables, the reason is future proofing. If I am going to run cable, I may as well allow for the possibility that I may choose at some point to use the AmpliFi as the primary router and gateway provided the firmware and such matures to provide items I simply will not do without, e.g., client/server VPN support at a minimum. After talking to some folks at Ubiquiti, whom I have no reason to question as I have worked well with Ubiquiti in the past, such things are in the pipeline, but no ETA on when they may make it to release. Whatever the future may hold for AmpliFi firmware/software updates, we are not there yet, so the AC68U is staying put.
Thus begets my question, which I now see is preceded by a novel (sorry): I would be grateful for any insights from members with experience or who otherwise have knowledge regarding optimal setups for running a mesh routing unit alongside Auswrt-Merlin, and if someone has specific experience with optimizing the AmpliFi HD and RT-AC68U (Merlin), all the better. This is not "I can't get it to work" question; rather, I have the AmpliFi in bridged mode and it "works" to the extent that WiFi clients connected to the AmpliFi get out through the WAN. Instead, I would just be interested to hear of any optimizations that I may want to consider for this type of setup based on the experience of anyone who may have done it already. Also, to the extent there is another good thread addressing this, just point me in that direction! Lastly, I realize I could likely just sit the AC68U where the AmpliFi currently sits, then apply same principle re one cable for wan and then one back down to the switch, but I have rambled on too much already, so I only add here that I did consider that option and decided against it.
