thomaswillner
After installing the original ASUS Firmware and then installing Merlin again it still shows all the tools as "open" and then they don't work. Why is that? Please help
You also need to format the jffs partition under Administration/System to clear out the scripts that install into it.OK, thank. I wonder why AdGuard Home shows as uninstalled FYI I formatted the USB ext4. So I think ATMT is showing this because it's in the database on the router as active?jYou need to also format the Jeffs partition under Administration/System
I already answered this question in your other thread. If hadn't created a duplicate post you would have seen it already.OK, thank. I wonder why AdGuard Home shows as uninstalled FYI I formatted the USB ext4. So I think ATMT is showing this because it's in the database on the router as active?
Welcome To SNBForums
