Frankie Yuen
Would like to setup a mixed Ethernet / wireless backhual mesh network that supports a guest network with captive portal - also need OpenVPN by the way, any advice?
i correct youCorrect me if I am wrong but Unifi itself is not a router, so do I need to have a router for a complete network?
kind of depends on your exactly requirement, and bandwith.
in general an usg-4 pro should be able to handle all your needs now and for some time to come.
plus add some smaller unfi switches,and you should have everything in 1 console for configuration, management and monitoring
send from a mobile device, so typo's are to be expected
Sorry I meant UniFi Security Gateway.A switch is not a router.
Welcome To SNBForums
