Asus Merlin 388.2_2 speed test history not working
Cream
Is it just me but on my Asus RT-AX86U running Merlin 388.2_2 when I do an internet speed test on the router it runs but it doesn't keep a history of previous speed tests. Its just blank. It was handy to see what see what your previous speed teed tests had. Maybe its a setting and or bug?
Thanks folks.
same here
I'm seeing a history maintained. Check the contents of directory /jffs/.sys/OOKLA for a "ookla_history" file.
This issue is present even in newer stock Asuswrt 386_23285. Web History freezes as well from time to time and needs router reboot to recover.
The web history on my rt-ax86u after updating to Merlin 388.2_2 has been working without failures for 6 days. But the history of speed tests is no longer saved, like the author of this topic.
Internet Speed History working on a RT-AX86 Pro running 388.2_2.
I believe everyone has seen it working. I see this on stock Asuswrt right now:
The same was happening on 388_22525 (388.2 base) and now happens on 388_23285, RT-AX86U router doing basically nothing.
This Ookla bloatware has to be removed from the firmware. Not needed and inaccurate, CPU limited.
I agree the speedtest app is more accurate since it won't have to deal with the router cpu.
Great. Problem solved.
I know they've upgraded the ookla exe a few times over the years, so it's possible that newer versions are better able to use multiple CPU cores.
The problem before was crashing. I don't see it crashing now, but it loses the history.
My history is working but I rarely run this from the router my test I just did is listed aswell as some from like 2 years ago.
History is stored in a JSON file under /jffs/.sys/OOKLA/
Probably, but I'm not going to investigate what's wrong. My router is on stock Asuswrt at the moment. I mean... the thread is posted in Asuswrt-Merlin section, but the issue is in Asuswrt. It was reported already and hopefully someone at Asus takes a look before the next firmware release.
After I looked at the contents of the files in the /jffs/.sys/OOKLA/ folder, the history of the speed test suddenly began to be saved. Miracles.
I had the same problem so i tried reformatting the JFFS partition and speedtest history started working again.
I use spdMerlin for my speedtests, but after reading this topic, I wanted to see how it woks here. It used to work with previous firmware versions.
I get this (my internet connection works well):
Screenshot 2023-05-27 at 12-04-21 ASUS Wireless Router RT-AX58U - Internet Speed.png
