ROO2020
I have a GT-AX-11000 as my main router, and a RT-AC5300 as my Node that is hardwired to the 11000. They are at completely opposite ends of the house. How do you update the firmware for the Node? I have tried to update the 5300 but the 11000 keeps trying to use the 5300 update so I have to stop it. Do I need to disconnect the 11000 run the 5300 directly off modem to update, then set back up with 11000 being the main router? ASUS sends me a link and I already know how to update the 11000 without a Node. Some reason they do not understand I using a AiMesh, with the 110000 as the base, 5300 as the node. It has to be a easier way to update the firmware each time on the 5300. Thanks.
