So i've had a weird issue since the first day i've bought this router whereas not a single browser port forwarding test can detect any ports i open when i use wan->Virtual Server / Port Forwarding page in the router settings.
Also while 9 out of 10 games and programs seem to be working just fine when it comes to online gaming and connections - a couple of them either don't work and require manual port forwarding and do not detect UPnP even if they actually work online.
The only way i seem to be able to test my ports is to download a software (pfportchecker seems to work fine) directly on my pc and run it. Even then some games would claim that i did not open my ports or did not enable UPnP, and browser based tests won't detect those ports. I've also tried using a software which uses UPnP but it couldn't apparently detect any ports and i wasn't able to find anything else similar to test it again.
My windows firewall (im using windows 10) is completely disabled and i've tried disabling avast internet security shields as well (i've used different av software with exact same results). I've also got something called "real dynamic IP address" from my provider instead of just "dynamic address".
Is there any other reason why i can't test my ports in the browser or why some software and games can't seem to detect UPnP and open ports?
