PartisanEntity
I have stock firmware version: 3.0.0.4.386_48260-gd4c241c
I have configured and enabled an openVPN server on the router.
At the moment in the openVPN configuration under VPN Subnet / Netmask I have: 10.8.0.0/255.255.255.0
Now in the router under LAN > IP Adress (not in openVPN settings) I have: 192.168.1.1 and under Subnet Mask I have: 255.255.255.0
Question 1:
Can I put the openVPN Subnet on the same Subnet as my LAN? Any drawbacks to doing so and is it even possible?
Question 2:
Is it possible to bind a specific IP in openVPN to a specific openVPN client? And if yes, how?
The reason for question 2 is because I have a server at home that is sharing some files over NFS and Samba and I have certain folders that can only be accessed by a specific local IP address.
When I connect to my openVPN server from the office, since my IP number is for example: 10.8.0.6 I am unable to connect to the folders. But if I am going to add IP numbers from the openVPN Subnet then I want them to be fixed for each openVPN client so I don't have to edit configurations all the time.
Question 1:
Question 2:
