Asus RT-AX88U Not Getting 1 Gig Connection
Shahzada
Have Virgin 1 gig Connection while on Lan on Virgin hub i m getting full 1 gig connection
While on this ( Using Hub as in Modem Mode only ) Max I'm getting is 500Mb on the same connections
on Ethernet
L&LD
Part of the Furniture
Shahzada
Consider testing the latest Alpha 1 release.
Download | Asuswrt-Merlin
Or, try flashing the latest RMerlin release firmware (again).
If you haven't performed a full reset to factory defaults in a few firmware updates (or ever), you may want to follow the suggestions in the links below.
Fully Reset / Best Practice Setup / More
[Wireless] ASUS router Hard Factory Reset | Official Support | ASUS Global
Almost all L&LD Links
First day since i got the router - installed Merlin straight away
L&LD
Then you need to do the full reset to factory defaults right away.
RMerlin, not Merlin.
L&LD
As we are on these forums, it is RMerlin. ;)
L&LD
RMerlin powered router(s), or more properly Asuswrt-Merlin firmware (as you stated). But not Merlin, ever.
That's like meeting Richard and calling him Dick. ;)
Calix_Cat
Hi @Shahzada did you get your speed up? I ask as I have the same router, same 1Gig upgrade from Virgin and highest speed recorded on the Adaptive QoS Internet Speed tool is 745Mbp (usually only 600Mbps) although I'm on firmware 3.0.0.4.386_45898-gfa90458 (the latest) from Asus.
Shahzada
nop
shoman94
Not really. You're installing a firmware (Asuswrt-Merlin) not a person (RMerlin)..... I hope. :D
Are you guys really arguing about the name?
leerees
You need to enable 160mhz channel to get the full 1gbps.
