LeKeiser
Hello everyone,
So I had a very good Netgear R7800. Was very happy with it, great WiFi coverage, it could handle my 28+ devices like a champ running with Mr @Voxel firmware and Mr @kamoj add-on. But lately, the 5GHz radio started to fail. So I started to look for a replacement in case it would definitly die on me.
I had precious councels here and I had a good deal on a RT-AX88U Pro. So I went for it.
The installation was a bit tricky, I had to use the Asus App on my laptop to start the configuration. After an hour, the router was up and running.
WiFi coverage is OK. My R7800 was a bit better it seems. Especially with the 2.4GHz.
The GUI is much much better though. At least to my eyes
I still have a few questions, if I may post them here.
_ I'm running the latest Asus firmware. So far, so good. Is there a way to check the temperature of the CPU ? A command to launch in the terminal ?
_ I upgraded the firmware but didn't reset the router after. Bad decision ? If I do reset it, I'll lose all my settings, right ?
_ I configured the AiProtection. Is it any good? Does it take a lot of ressource ?
_ I used to have a port triggering config on my R7800. I had to enter the port number, the protocol (TCP/UDP) and the destination IP. I see that it's different with the Asus. Port Trigger. I have to enter 2 configs, one for TCP, one for UDP. And there is no option to enter the destination IP. Is this normal ?
I'm sure I'll have some more questions as I use the router these coming days.
Thanx a lot for your comments
