Hi there,
I'm new to the forum, but I have a problem I cannot seem to get solved....
My situation;
I have internet (and TV, Phone) from KPN (The Netherlands)....
Therefore I have a EXperia Box v8
Connected is a ASUS RT-N66U router (operational as a router)
I have 2 IP addresses I need to be able to access from outside my home network.
So I have made the next adjustments;
ExperiaBox;
- at DATA - FIREWALL - DMZ.... I checked the box "DMZ function enabled"
- at DATA - FIREWALL - DMZ... I put at CLIENT PC IP Address the IP address of the router
- at START - LAN... I put the Mac Address of the router as a Static DHCP at x.x.x.250
- WiFi is turned off
At the Asus RT-N66U I made the following changes;
- WAN IP is set at x.x.x.250
- WAN Connection type is automatic IP
- Enable WAN, NAT en UPnP
- Connect to DNS Server automatically is set to YES
- At PORT FORWARDING I added the 2 IP addresses with local port set at 80 (for both), protocol set at TCP.
OK, so with these settings I can reacht the right IP Address from outside the network.
However, when I try to login to my banking account (login at ING), the webpage doesn't appear and I get the error CONNECTION TIMEOUT
If I change the CLIENT IP address in the Experiabox to (for example x.x.x.2 or x.x.x.17) I can get to my banking account login page, but (offcourse) I cannot reach the 2 IP addresses from outside my homenetwork.
At first I thought it was a problem of my router, but if I hookup my laptop (bij UTP) to the Experia box the same thing occurs....
I also tried to get rid of the problem by installing the latest firmware for the ASUS router, but that didn't do it, even getting it back to the former latest firmware didn't help.
I'm really stuck here (obviously I'm not the network specialist, but I do my best by thinking logically....)
So I hope someone can help me out....
Ludo
My situation;
ExperiaBox;
Ludo
