AX86U loses internet connection 2-5 times a day. Help!
Keiraija
It's on 386.7_2
- Try hard reset and leave settings at default.
- Ax86u dials pppoe
It will lose internet and the setup page (of ax86u) seems to freeze during that time few times a day.
Doesnt seem to happen if I use tplink er605v2 to dial pppoe and put ax86u on AP mode.
Any hints would be appreciated.
My suspects: AiProtection or Symetric/Fullcone mode???
Thanks!
L&LD
Part of the Furniture
Instead of AP mode, try using the router in AiMesh Router in AP mode, with the TP-Link radios turned off. If you can't simply put the TP-Link in Bridge Mode, of course.
Keiraija
Tplink acts as a router that dials pppoe, ax86u acts as main Aimesh AP + 2 ax55 as nodes. And internet will be fine.
If I turn ax86u back as router, remove tplink from the chain, and dials pppoe, internet dropout occurs again :(
bbunge
There is an Asus beta firmware for the AX86U that I recommend you try.
