DL Master Won't Login
Mazz
Good day, I have an Asus Rog AX-6000, Current Firmware. Since i bought this router DL Master will not Login, invalid Name or Password. It's the same name and password as the login to the router, i can see my files in Networking on Windows 11, i can login with my credentials. I have factory reset the router, tried multiple external drives, tired Windows 10 and 2 different Chromebooks and same error. I have also deleted anything to do with the router in all browsers(cleaned cookies and deleted from password manager) and same issue. Anyone else with a AX-6000 and use DL Master get it working?
i have the same problem with the download master windows utility but not from web GUI
I can access Download master web GUI
follow my steps if u have trouble with the Web GUI.
Thanks, changing the password to something longer worked! I changed the password multiple times but usually around the same length. been trying for Months to get it to work, never had issues with my other 2 Asus routers.
U got it working is on the web GUI or the windows utility ? how many characters did u use? and how many symbols or letter or numbers?
Can tell me the detailed steps u used?
I don't use the Windows program, had only installed it to see if i could login and i couldn't then. All i did was change my Password from 6 characters to 12, added 1 capital letter, symbol @ and added 2 additional numbers then restarted the router. Before all this it would not login to the Web Gui or the Windows Apps. I don't use the Windows a[pp because i can't remove completed tasks on it, it always gave me an error.
I finally got the windows app to work. Just have to delete the username and password fields and re- enter again and it connected.
