I am paying for 500mbps down from my ISP, which I can get if wired directly to the modem. However, I'm getting no more than 95mbps when the GT-AC2900 is anywhere in the stream. Speed tests are consistent across wired device, wireless device, as well as the test directly in the router's web interface.
I have performed factory reset, updated firmware to latest (3.0.0.4.386_51529), and am using the ethernet cable where I confirmed 400+mbps directly from the modem. I also tried enabling Dual WAN and setting primary WAN port to LAN1 in case of faulty port.
Not getting much help from official ASUS support, so hoping for some bright ideas here.
Edit: Solved, but I don't have much advice to any future Googlers. Things just started...working.
