Skynet Force Skynet reinstall
bromo
My USB thumb drive failed. I replaced it. I reinstalled Diversion but I am not able to reinstall Diversion via amtm. Skynet times out waitting for the USB drive.
Skynet: [*] USB Not Found - Sleeping For 10 Seconds ( Attempt 1 Of 10 )
I am unable to either mange Skynet or reinstall it from amtm. Is there a cli e a cli command to either disable skynet or reinstall it?
I think the easiest thing to do is delete or rename /jffs/scripts/firewall-start and try again.
I ran into the exact same situation. Deleting the /jffs/scripts/firewall-start let me reinstall it however I'm getting the "Skynet: [*] Lock File Detected..." error. How do I resolve this?
firewall uninstall
and then re-run the installation
make sure you you have a new working usb 3 with ext partition and format.
