Guest WiFi - stop full network access
TomT
Hi
I've created a guest WiFi and selected Access Intranet OFF
Yet clients have full LAN acess. How do I stop this ?
They are also getting there IP address from the DHCP server and are in the same range..
Double check your settings, what you have should work.
Make sure the clients don't have an old "profile" that lets them connect to the non-guest network.
Reboot the clients as well as the router. The clients might be caching some old information.
The DHCP addresses are correct. They have no bearing on whether there is access to the LAN or not.
Thanks the settings look correct but I can still pimg devices on the LAN.
I'll check my start up scripts tomorrow to see if any could cause an issue.
How do you edit a guest LAN ? I only get the option to remove. If I then re add it it comes back with the same settings.
"Yet clients have full LAN access".
Don't just rely on "ping" because it only uses ICMP, not TCP or UDP. What other access to the devices do you have?
