How to remote access get-ac5300
buggs1a
Hi. I’ve set up correctly the ASUS gtac5300 for remote access and when I try to connect to my router it just won’t connect. Timeout I think. LAN is fine.
I have it set up correctly though.
I think the mobile app works saying DDNS but I don’t see how since I never told it where to connect. I just opened it and It says DDNS.
So if it is then a browser should too.
bbunge
You really do not want to use the remote access in the Asus app unless you want someone to hack into your router. If you need to remotely manage the router or access resources in your home network, set up DDNS and OpenVPN server (on a port other than default). Much more secure.
