Increase in home WiFi signal
Alaska_av8r
My home is 2 levels and around 2000 sq feet. My Asus wireless router sits on the second level and the signal is very weak in the bottom bedrooms. My home is hard wired with a lan connection in each room and I have all that running through a switch.
I don’t know a lot of the terminology or what various items do but with my existing setup is there anything I can hook up to my lan connection downstairs that would re-broadcast the the same network wirelessly eliminating the need to re-login or switch networks?
in other words what is the best method in my case to achieve whole home WiFi
thank you
Tim
L&LD
Part of the Furniture
Alaska_av8r
I have the AC88U router and I haven't updated it in over 3 yrs but I think I'm running Merlin on it. Just checked running WRT Merlin not sure what version.....
