Hello all,
I am trying to get rid of my ISP modem/router (optical fiber network). I do have internet and TV and receive it separated in two Vlans.
To do this I am using a GPON modem and an Asus RT-AC68U with the latest Merlin Firmware. I did a lot of research before asking here and get almost everything to work, the only point is that the TV signal does not stay for longer than 10 seconds (if I change channels the signal is back for 10 seconds and falls again).
I tryied to cover all through several scripts but I don't know if I did it right, below the commands to cover it all(in red):
1-
IGMP Source – Enable
IGMP Proxy – Enable
2 - NAT – Enable
3 - Firewall – Disable
4 - IPV6 - Disable
I really don’t know if all the commands are properly set and if this is fine with the last Merlin FW, furthermore I can’t find the proper commands to check it, if anyone can help me to clarify that I would really appreciate.
Thanks in advance.
Best regards.
1-
IGMP Proxy – Enable
@igmpproxy.conf
phyint vlan20 upstream ratelimit 0 threshold 1
altnet 0.0.0.0/0
@services-start
snooper -s vlan20
It also requires No Multicast VLAN Filter, which I used the following.
@nat-start
/bin/echo 0 > /proc/sys/net/ipv4/conf/vlan20/rp_filter
altnet 0.0.0.0/0
@services-start
snooper -s vlan20
@nat-start
2 - NAT – Enable
@nat-start
iptables -t nat -I POSTROUTING -o vlan20 -j MASQUERADE
It also asks to Enable Fullcone NAT – I can’t find how to do that.
@firewall-start
I can't find the proper command to disable the firewall for vlan20 only, so I have opened all ports related to IPTV services.
4 - IPV6 - Disable
@wan-event
echo 1 > /proc/sys/net/ipv6/conf/vlan20/disable_ipv6
Thanks in advance.
Best regards.
