Migrate to Wireguard Manager
Just using a client’s to connect to my TorGuard VPN
Then its just to reset your client config, copy it and remove the # you put in.
Stop your current script from executing and reboot so your old wg vpn session is not running (will conflict)
Then import the config into wg manager:
https://github.com/ZebMcKayhan/WireguardManager#import-client
For further tweaking and settings you find most information you need here:
https://github.com/ZebMcKayhan/WireguardManager#table-of-content
Good luck!
