Multiple DHCP scopes 87r
stiffbeta
HI,
Is it possible to configure multiple dhcp scopes on an 87r for the guest wifi? I'd love if it were possible for the lan too but after many many many attempts to create vlans and having to reflash I wont go that route but hopefully I can do it for my guest networks?
I'm on 380.59
Not through the webui, but if you search the forums I remember people posted a method to manually accomplish it.
thank you I have found some post to use dnsmasq so will try that. I'm hoping it doesn't brick it like messing around with vlans does lol
