macster2075
Hello,
I'm going to try to explain my setup and the issue I am having. Please bare with me as I may not use the correct technical wording and such.
I have 2 Routers, one on each corner of the house.
Router 1, (main network) 192.168.1.x (connected to ISP modem) provides internet access for personal devices.
Router 2, IoTs and security cameras 192.168.2.x
I run an NVR (Blue Iris) on a PC that has 2 NICs.
On the other side of the house, where Router 2 is, I also have a couple of PC that connects to the Main Network, Router 1 via Ethernet cable.
I ran an Ethernet cable from Router 1 LAN to a switch which is next to Router 2.
Now, from that switch, I can provide internet access to both PCs on that other side of the house using Ethernet.. great so far.
NIC 2 on that NVR PC, I set it to 192.168.2.x static IP range.
It's hard to explain what I am trying to do or say, but here it goes....
Router 2 needs to have DHCP enabled to provide internet access to devices connected to that network and be separate from the main one.
The issue I am having is that, if I connect an Ethernet cable to the WAN port on Router 2, I lose internet access on devices connected to it. I don't know why.
DHCP is enabled, but no internet access.
Also, if instead of using the WAN port, I use the LAN, then wireless devices will have internet access, but will be getting IP from Router 1 network!.. huh?
So..
Router 1 LAN to Router 2 WAN, No internet access.
Router 1 LAN to Router 2 LAN, then all devices connected to it get IPs from Router 1, 192.168.1.x network.
I can't figure this out!.. Please help. I'm sure it must be something really easy, but I am sure I am just overlooking it.
Is this even possible? I mean, it sounds like it should work fine.
So..
